Are you looking for a new switch? Or a used original switch?? Centerline has a re-worked Fiat switch that they sell to replace the Alfa ignition, but make sure you speak to Carl to go over the wiring, as it is a bit different and not a wire for wire replacement. Switch looks OK in the column, but isnt an exact match. Good luck!
