1 - 12 of 12 Posts
member
i am having engine work done, (spider 2000 1992) and seems the front crank pully is leaking oil. mech has not had any luck finding one...any ideas?
i sort of remember there was a place in calf, that had salvaged parts, but have not found it again, perhaps it is gone? but i would prefer to put a new part.
thanks guys.:grin2:
member
I might be wrong but doubt pulley has anything to do with that leak. Wait for others to chime in before replacing it.
thanks...he is repairing a timing chain disaster. and has had the engine apart...he is suposed to know what he is doing( i hope) but i will , as you suggest , wait for more chimes. we can all use as much info as is available.
Crank pulleys can crack, and they can get grooves from the front main seal, but I agree that neither is the cause of the leak. If it is cracked, it needs to be replaced, but if it is grooved, you can probably install a speedi-sleeve.
The place you are seeking is APE..
Alfa Parts Exchange.....
Should be listed as a parts vendor here on the BB.
I am curious to know why the mechanic says you need a replacement pulley?
As said, you may only need a new seal or a speedi sleeve to address a groove.
Vin
member
Vin
i am going back in the morning armed with this information, and ask him just that...thank you...
1 - 12 of 12 Posts
