1 - 11 of 11 Posts
Greetings:
Recently decided to move up a race class that will not only allow me to change suspension (springs, bushings, bars) but also the use of 7 inch wheels.
There has been a debate on whether to also upgrade to 15 inch x 7 but I am afraid of the potential interference with the tire rubbing against the fender.
Comments welcomed. Plan to use 205/55ZR/14 or 15.
Wheels need to be 108 mm bolt pattern (for 1973 Alfa GTV) and I am not sure what the offset is given the above parameters.
Your assistance much appreciated.
My location is New Hampshire.
I have 205/55-15's on Rota wheels on my street GTV with no clearance problems. But generally you would want to use a smaller diameter tire on a race car. If you do go with 15's, I would consider 205/50-15 tires.
15x7x108 Campagnolo Turbia
The wheels he is having produced at this moment are 15x7x108 Campagnolo Turbinas. They are an updated version of the 14x6 1/2 wheels fitted to the Montreal. if you want a set you have to order from him now in order to get in on the production run of 60, 5 wheel sets.
im looking for 14x7 mille miglias, melbers, ronals, tecnomagesio, or 13x8 4 spoke campys for 105's.
if you hear of anything 14x7s that i can pick uo, i will GIVE YOU six of my 15x7 108mm wheels i have in my garage for as a finders fee. these are ford types that ralph gilles use to run in his blindinly quick 69 GTV so they should fit.
best of luck with you search
davbert
The PO fitted Ford Mustang turbines to my Berlina and with 195/60R15 tires they fit fine.
The hub center will need to be drilled out to fit over the Alfa hub, but that's it. Cheap and plentiful, if not super light.
I'm not sure how they did it, maybe pulled out the fenders slightly. But they fit.
Look for my intro thread in the Sedan section.
Discussion Starter · #10 ·
Thanks everyone:
I see Group 4 Wheels is located in the UK but the e-mail address provided is different @yahoo.
Very hesitant about getting 15 inch wheels. I see the advantage because I can get group discount on Hoosiers from the Miata class who uses 15 inch but I am afraid of the interference. You can imagine how scary it can be if you are handling a bumpy turn going full out and it hits the fender, won't be a pretty sight.
lowered suspension and stioffer springs will help eliminate body roll but may further aggravate interference with fender depending on offset.
Hoosiers does sell P205/50ZR15. not sure the profile change from 55 to 50 will be sufficient.
15" wheel/tire combos won't be any taller or wider if u use the right size tires. Ask around lots of people have gone there.
1 - 11 of 11 Posts
