Hi, I had my (1969 GTJ) gearbox rebuilt with new synchros, bearings, etc by a well known UK Alfa gearbox specialist, but even after getting it back and using MT90, it has whined quite a lot. Recently, it seems to have developed a rattle when in neutral with the clutch out. The box has done less than 1000 miles since the rebuild, even though this was done around 5 years ago. I think I'm going to have to pull the trans and rebuild the box.
How do I identify if I have an early or late gearbox in terms of the bearing shopping list required as I understand there may be some differences?
Does anyone have a list of ALL the bearings required, along with part numbers? I'd prefer to use top spec bearings if possible to ensure this is a one off job.
If all new bearings are fitted, would there be anything else to then cause a whine similar to what is heard in a straight cut 'box?
I've checked the usual suspects like the boot/gaiter around the gear lever housing. The rattle increases with revs off idle and can be heard when driving (until road noise increases too much).
I would ship the box off to the specialist again, but I've lost faith in what they did given the hassle I'm now facing. The box was sent to them by another well known UK Alfa specialist on my behalf.
