1 - 1 of 1 Posts
could you remove these on a lowered car? and perhaps replace the stock bump stop with something, lets say ' better '? i have found when you lower a spider, you get/or very close to the stock bump stops.i like the way my car sits, and i will raise the rear end about 10 mm to get the look i want.. my resr spring are coil overs 145 lbs/inch, with qa1 adjustable shocks. so i can tune the rear end a bit with the coil overs.
1 - 1 of 1 Posts
