1 - 5 of 5 Posts
I have my thermostat housing off while I'm repairing my head and noticed some limescale built up inside. Not a ton, but some. Is standard issue limescale remover safe to use with the aluminum housing as well as the thermostat? I just figured I'd clean it up a bit before I reinstalled it.
Also the gasket doesn't look particularly great. Hmm.
You might try soaking it in vinegar. That's good at removing calcium without really hurting the aluminum. With the hard water we deal with here, I use vinegar a lot to remove calcium build up.
Thanks, I'll give it a shot! Everything I had at the house that was labeled as limescale remover also said explicitly to not use on aluminum.
Hopefully it'll work and at the worst it might just clean up the aluminum a little. I think I bought a new housing when I changed my timing belt last time around so they're available if you need one. I changed the gasket when I changed mine too.
I have a new set of gaskets for pretty much everything I just pulled apart. I honestly don't know how some of them were doing an even remotely acceptable job.
1 - 5 of 5 Posts
