Richard Jemison
Light, 10.3 lb "0" balanced, flywheel from TS fitment, but will fit all 2 liter transaxle type application (Alfetta). Requires 131 tooth ringgear.
Stock flywheel is over 21 lbs.
$350.00 and $25.00 shipping in USA.
Hi Richard, I'm not too familiar on the balancing arrangement for the Alfetta engines, so I have to ask whether this will be a bolt-on application or whether it will require further balancing of the flywheel or engine to suit?
Richard Jemison
Flywheel
For typical Alfetta applications you would have to use a 131 tooth ringgear (from a more common 90-94 Spider and matching starter.
Look at the Alfetta version which would be bolt on. No balancing since "0" balanced now.
