1 - 15 of 15 Posts
You should check some of the Alfa parts suppliers. Also Fiat parts suppliers. Alfa part number 115.48.96.025.00 and Fiat part number 60519098-G. Check in US, Canada and Europe. Someone has one.
If you want an alternative, here is what I did. Of course, leraned it here on the BB.
The relay turns the lights off 20 seconds or so after the doors are closed.
This simple mod, instead of the relay, turns the lights on when the doors are opened and shuts the lights off when the doors close.
Good luck,
Vin
vin, i would never do that to my fuse box. thank you for the idea but i would prefer having the relay.
No problem. To each his own.
Did you try Larry at APE?
Good luck with the search.
Vin
1 - 15 of 15 Posts
