301 - 320 of 350 Posts
It's years since I raced in our Lemon's Verde (which I believe was finally trashed a month or so ago after all these years of racing) but I think all we did was to remove the power steering belt. Brian, did we remove the pump and plumbing as well? All I know is we didn't do anything special and it held up for many years of racing. We never had any issues steering with it unassisted.
As for the ABS, we did remove ours, it can be a little tricky getting the new box in as the bolt/nuts are a little hard to reach. I remember lying on my back looking up in the footwell shouting out curses and I think there was a little minor sawzall action as I think we had a GTV6 box instead of the Milano which shouldn't need any mods.
We did as you mentioned and pulled out the sunroof and riveted in a panel. You can also see the cleaner sunroof delete I did on my old (non Lemons) Verde here: Alfa Milano Registry - Sunroof Delete which is obviously not needed in a race car but it was fun!
We did have some cooling issues and first tried a new stock Verde radiator but still had the issues so eventually went with an aluminum one from Jegs that was close enough to make it fit fairly easily. We also added an oil cooler, I don't remember having any cooling issues after that.
We used the stock verde gauge cluster but did remove the ARC. One thing to note is if you remove the ARC you need to deal with the missing alternator/battery light which acts as an exciter to get the alternator charging the battery. We didn't know this at first and had no charging going on, we later rigged a little light in the dash that did the trick.
Good luck, these are great Lemons cars.
Kevin
Thanks Kevin - very helpful.
When you say your verde was trashed, what do you mean? crashed destroyed or literally thrown away?
On that note, if ANYONE here has an Alfa racer they want to part with it, I'm all ears. Would prefer to buy a complete car and pick up the ball on development than start from 100% scratch.
Thanks! -Paul
Ditch it. I run an Alfetta non power rack, steering effort is fine. Ed's right though the rate is a little slow.
Respectfully I disagree. I have kept the power steering in my LeMons race car for the 10 years I have been running it, that along with keeping the stock brake master cylinder WITH the booster is a good idea in my opinion.
Because I run a big fuel cell I can extend some my drivers stints to 4 hours on a lot of tracks - crazy right? Why? Because the driver doesn't have to work very hard to drive the car we stay fresher and just as importantly safer. Long stints give us an advantage in our lap count and with 5 second place finishes (No wins) over the years we have done pretty well.
The power steering rack is fairly robust with a few changes. First you need to pin it together where it screws apart or it WILL come apart on you some time. Fresh hoses and a fluid flush along with washing out the reservoir is a good idea. Lastly I reseal the pump with O-ring and a seal to eliminate the annoying little leaks it has. The belt gets changed every year or two as well. Any deficiency in the pumps mounting bolts will also show up at some point if you don't go over them (Loctite the bolts that are not the adjuster bolts. Oh yes the mounting bolts / mounts need to be gone over whether its a power rack or de powered - they will loosen up eventually.
In 10 years and 24,000 plus miles of racing the power steering system has caused me a problem in 2 races. When it came apart and puked its oil we screwed it back together and snipped the drive belt. We were back racing in 4 minutes. the next time an oring in one of the hard lines failed and we "fixed" it even quicker.
But do as you wish. I just think that with all there is going on around you in a LeMons race making it easier for the driver is a good idea. Also with the power steering you can switch to a smaller diameter steering wheel which has the effect of quickening the steering ratio.
In my hardcore EP race GTV6 I use a depowered Milano rack to quicken up the steering. With wider tires I sure would not want to race that car in endurance racing.
Prior to the race at Thompson Speedway I had injured my left shoulder and having power steering was a big help in the race. Here is a short video of me trying to take it easy on my shoulder during the race.
Greg
Greg
Discussion Starter #305
Steering rack
I'm with Greg on this one. On the 5 Series Bimmer we bought to run while doing the transmission conversion to the GTV6 we put the power steering back on and the car is much easier to drive. I FINALLY found a new body for the GTV6 and it came with a Verde motor in it and a P/S rack. It is our intention to make the rack work with power and to really be wack we're adding 4 channel ABS to the car.
Paul, if you are in the Bay Area reach out to me and I'll be happy to give you all the pointers about running a transaxle car in Lemons.
Thanks! -Paul
Punted into a wall, from what I understand, too much damage to fix!
Kevin
Oh that sucks! Sorry man. Building another or moving on?
They have a new car in the works. I won't spoil the surprise, but it should be awesome.
Sent from my ONEPLUS A3000 using Tapatalk
Kevin, I think the radiator was from Summit, it was recommended by somebody on this BB I think. One can search the BB for the link, it was posted here. One benefit of the Summit radiator was that there was no longer any need for a 1-3/4" to 2" step up/down hose, the radiator has all 2" inlets and outlets, so you can just go to Autozone, find 2" hoses with the proper curvature, and start cutting. The other advantage was that it was less than $200, a fraction of the price of a new Verde radiator. I think it was sized for a 5.0 V8.
We also added a remote oil cooler. We had no cooling issues after doing all of this, including running all day in 113 degree heat at Buttonwillow a few years ago.
bs
OK, so @Caxny and I are finally building a car....GTV6 instead of a Milano. In the stripping process and have some questions:
* Helmet room/roll bar legality: It seems this is going to be tight. I'm 6'2" and we may have a driver even taller. I assume we should buy and test fit/mount a seat before doing the cage so we make sure that the roll bar/main hoop will be high enough and we also get the harness bar in the right spot?
* Any recommended seats and mounting methods? being lemons, we are leaning towards a sparco sprint entry level seat, but if that's a mistake, let us know. Whatever seat will need to be mounted so its adjustable - how do we get it low enough for adequate helmet room?
* Dashboard - seems a shame to completely rip this out as the guages all work and the center binnacle has lots of spaces for switches. Do you recommend keeping the dash, removing the dash but reusing the guage/switch binnacles or do people chuck this altogether? I've seen both on gtv6s online and one where a center crossbar was implemented with stock dashboard.
Thanks! Look forward to joining you guys, hopefully for a debut at buttonwillow in Sept.
Congrats!
Definitely buy the seat first. They make side mount brackets so ideally you can get the bottom as close to the floor or on the floor. We have a used Sparco that's comfy.
I am all for saving and sell was much as possible to help keep other Alfas on the road. If you can pull the dash do it, sell it to recoup funds and it will also lighten the car. You can keep the gauges if you want and figure out how to mount them somewhere.
This season we are working more on lightening the car since we can't really add power. The Milano was pretty reliable and we finished our first race but we will need to focus on brake cooling and lightening to be more competitive.
So Team Pro Crash Duh Nation finished 2nd overall at NJMP in its last race. Our car (Angelina) was pretty flawless all weekend. We finished in front of some teams that are usually really tough competitors but 5 laps behind the winning car. We made 2 mistakes that probably cost us 4 laps overall and another car hit me and spun me to cost us a lap and a half. But the winning car was faster and driven really well - Rust in the Wind Nissan 300ZX.
As Seneca said 2000 years ago "Luck is when preparation meets opportunity"
The car was better prepared than it ever was. the drivers not so much. The motor was very strong especially Saturday morning with the cold air, it is still working through a modified L Jet system with its AFM, so air density really matters. The latest chassis stiffening / repair I did really made a huge difference, the car turns in so well now its almost twitchy. It was losing camber in cornering due to chassis flex. That's fixed and the Hankook RS-4s show it by light, perfectly even wear across the face despite being tortured for 14 hours of racing.
The braking was very good due to a WORKING bias adjuster and the installation of the new SS caliper heat shields. Performatek has them now. After shattering 2 front drive shafts and having to dry clean my underwear 3 time in the last 3 years I fabricated a new stronger front driveshaft for the car. It uses .083" tubing instead of the .060" tubing from the factory. A local shop balanced the assembled driveshaft for me with everything installed using the tooling I made - it worked perfectly.
One of the areas that need improvement is the shift linkage. I switched to the GTV6 style linkage with a Milano shifter (longer actuator) but the pivot at the bottom of the shifter to shift rod is so sloppy we were selecting the wrong gear at the top gates a lot. So you go to 5th when you wanted 3rd or worse. I am mulling ideas on what to do about it. I may make my own rigid pivot or I may pick the nuclear option and install an in ****pit shifter and linkage setup. If anyone has any good ideas I'm all ears.
So with this 2nd place finish we now have FIVE 2nd place finishes - more than any other team in LeMons. Which gives us the coveted title of 1st "Always the Bridesmaids, never the Bride" title.
Greg
OK, so we have out GTV6 stripped and need to get a seat ASAP. Concerns are:
- We need a wide/XL seat that also can be set up to easily adjusts fore and aft (can you use stock sliders?)
- Sits low enough for helmet room and still stay under the cage enough.
- Comfortable yet budget friendly
Any recos? Wes I called you and left a message a week or two ago -- maybe just easier to post here?
We have a Sparco, I forget which model. I’m 6’1” 34” waist and I fit fine. I believe you need sliders with tabs on both sides. Check the rules. I think we used Recaro sliders.
Cage Help on GTV6
OK so we have our seat in and its Cage Time. Everything is sorting out fine, last detail is to lock down the final position of the rear hoop mount.
Long story short, it comes down to we are trying to decide between cutting out part of the piece that bar is sitting on in the photo below to get it in the ideal position for us or mounting the bar further back, which risks putting the rear mainstays at an acute angle and making the spreader plates less than ideal. Cage builder thinks that part is mainly for rear seat mounting and not structural, but has also offered to add a tab and secure remaining piece to the cage.
Any feedback you can provide on this would be really helpful. Where have you alfetta/GTV6 landed these bars??
Thank you! Also posted to lemons forum here.
