21 - 40 of 81 Posts
A bike ninja!
On a bike I've always liked lights in the wheels and reflectors on the pedals or shoes. Relying on motion (make the driver say "WTH is THAT?" from a distance) rather than brightness. I decorated my bike with LED Christmas lights in the winter when I used to commute by bike and I think that got more attention than anything. Not bright but a weird lighted up thing that got people's attention. Mostly though I just stuck to back streets and kept my head on a swivel!
The assumption I was making was that the LED lamps would be brighter by some factor, but overall the overall power consumption would be lower. I was not even thinking about equivalent power consumption LED replacements. The idea of putting in bulbs that are 10x brighter than stock doesn't make any sense to me at all. 3-5x? Sure, seems reasonable. 10-15x? No way.
Yeah, that's the way to do it. Get a little brighter (or a lot, just not crazy!) with a lot less power consumption. I think people just get carried away when they see the possibilities for going super bright using existing wiring and sockets.
I am using an older style led blubs the yellow is equal to 2 to 5 watt (9 led) and white 15-20 watt (19 led). Everybody comments they are brighter than stock. Shown with lens off.
The problem with an S2 is that there is absolutely nothing that could be considered "high" on the rear end of them. But maybe a little LED strip light on a tiny stalk coming up from the trim around the top? You can get some very compact LED systems that are quite bright. These guys have (perhaps literally) a million options: https://www.superbrightleds.com
edit: Brainstorming this a little. My first thought was a led strip right below the trunk lid. That would get it centered but still below the bumper height of a lot of SUVs. But you could make it fairly wide and I'm sure you could find a simple Instructables project for making it animated to catch attention. And didn't US S4s come with a trunk-lid mounted "pod" for a high mount? Like the one in this picture:
Thanks GV
I've tried the bulbs with LEDs only pointing forwards, like those in post #22 by alfabeach.
Because they only shine outwards, you don't get much multiplier or spreading factor from the reflector, and you end up with a very bright, but tiny, dot in the centre of the light unit. Better to buy bulbs with LEDs all around, as shown in earlier posts.
I bought this red tail light pair from Amazon for $13 with free Prime shipping: https://goo.gl/djppSS This is the title to search for in case the link goes stale: "LUYED 2 x 650 Lumens Super Bright 1157 3014 54-EX Chipsets 1157 2057 2357 7528 LED Bulbs Used For Tail Lights,Brake Lights and Turn Signal Lights,Red"
Today I finally had the time to install these bulbs which I too ordered from Amazon based on ihart's recommendation.
All I can say is Wow!
The improvement in brightness is dramatic, as others have said and shown in pictures. These 650 Lumen bulbs make my 74 Spider's tail lights look like those of a modern car.
For others who plan to do this swap, once you have the light assembly open you should:
  • Clean the ground wire connectors, washers if present, and nuts
  • Clean the tail light reflectors and the red lenses
I painted the reflectors on our sons's GTV 6 using Spaz Stix (yep-- that's the name!!) chrome aluminum spray paint, available at most hobby stores. Google it and you'll see many modelers like the bright finish to replicate polished aircraft aluminum. Makes a ton of difference in reflectivity.
Out of the office!
I would like to see some pictures taken at night. Would that be possible?
Hi,
Will these lights work on a Series 1 Roundtail Spider ?
I tried some on my roundtail and found them to be quite dim.
I installed the red 650 lumens parking/brake LEDs as described earlier in this thread. While they are brighter than the regular bulbs (LED on the right), it's wasn't a huge difference for me. My incandescent bulbs were new as of a few months ago and I had cleaned the grounds and cleaned up the reflectors so I'm not necessarily surprised.
What did make a difference was the turn signal LEDs. I have amber turn signal lenses so I used the LUYED 2590 lumens LEDs (no external resistor required). I was too lazy to stitch the videos together but if you start them both at the same time you'll get a pretty good comparison.
There are lots of different LEDs out there. You need to buy a high-quality one with a good light pattern for your setup. You also need to match the LED color to the lens color.
I put some LED 1157s brake lights in the Giulia and it was a world of difference. The main reason was to help prevent the brake light switch from burning out, but it helped a lot with visibility as well.
The bulb I used projects mostly forward with a 130 degree beam angle, but this did a good job of lighting up the Giulia reflector. For different applications a different LED pattern may work better or worse.
https://www.superbrightleds.com/moreinfo/tail-brake-turn/1157-led-bulb-dual-function-1-high-power-led-bay15d-retrofit-car/808/
180 degrees. And LEDs *should* run cooler, except when they contain a resistor to activate a flasher relay. It would be better to buy ones without the resistor, and just get the electronic flasher relay. Or put your own resistor in-line, just away from the plastic lamp housing.
Definitely get an electronic flasher.
And LEDs run cooler. My FLIR infrared camera confirms what my hand first told me, LED generate little heat.
I also suggest using a LED bulbs for the interior lights. I have GTVs and using the LED festoon bulbs have eliminated the problem of the translucent plastic lens covers on the interior lights being melted by heat put out by an incandescent bulb.
For at least the last 10 years I've been buying LED bulbs and accessories online from Superbrightled, Their products, along with technical assistance and their customer service are first rate.
Bob
Attached is a night picture of my S2 with new red LED tail / brake bulbs.
Sorry, I do not have any before pictures with standard incandescent bulbs. Suggestion for the next person doing this swap it would be nice to see night pictures of incandescent bulbs both before and after cleaning ground connections.
Hard to judge from a picture but do you not consider that there is a point where they may be TOO bright? Because if they are approaching the level of brake or rear fogs then they really can be an irritation to the person following you. I know LED technology has given us super bright lights but in some cases like police and other emergency vehicles it has been taken to such an extreme that you can't actually look at them and they even wash out the hazard by blinding the driver. I know the idea is to be seen but my gosh yes, I see you already, enough!
With modern cars there seem to be two unintended mistakes by drivers. Either they are driving with front and rear fog lights lit on a perfectly clear night or they are driving with just their DRL's on completely unaware that they have no tail lights because their instruments are LED and are lit up all the time.
That corona around the lenses is not visible to the human eye -- it's an artifact of my Samsung S7 camera's digital processing.
When I get back to CA in early January I can see if there are night photography settings on the phone or try my digital camera.
I do not think that they are too bright, and FWIW I am sensitive to oncoming, too bright headlights.
In retrospect it would have been better to have had the Forester's tail lights on for comparison in the photo.
The 1157s I linked to, while brighter than stock in the Giulia, are not excessively bright. They're pretty equivalent to what you see on a modern car.
In town, not sick, no rain, so I got pictures tonight of new LED taillight bulbs. Turned on the 2014 Forester's lights for comparison. Although I do not have before pictures with original incandescent bulbs, pictures below show that these 650 lumen LEDs have reasonable brightness levels.
Based on my happy experience replacing tail light incandescent bulbs with LEDs, I decided to also replace my rear turn signal and back up bulbs with LEDs as well.
Here's what I ordered from Amazon:
5 White LEDs for $12.99: AUTOUS90 5 x 650 Lumens 1156 1141 1003 3014 54-EX Chipsets Led Bulb Used For Back Up Reverse Lights,Brake Lights,Tail Lights,Rv light,Xenon White
5 Red LEDs for $12.99: AUTOUS90 5 x 650 Lumens Super Bright 1156 3014 54-EX Chipsets 1156 1141 1003 7506 LED Bulbs Used For Tail Lights,Brake Lights and Turn Signal Lights,Red
Bought, but did not use, 4 LED load resistors: Zone Tech 50W 6Ohm LED Load Resistors - 4-Pieces Premium Quality LED Load Resistors for LED Turn Signal Lights or LED License Plate Lights or DRL (Fix Hyper Flash, Warning Cancellor)
Based on reviewing many LED listings on Amazon I think that these AUTOUS90 ones with 54 SMDs (Surface Mount Device) are a newer generation and are thus, hopefully, better in some way than previous generation(s). It seems that older generation LEDs use fewer, larger SMDs. Their cost was also attractive.
I did not order amber LEDs for the front turn signals and running lights, because I am more concerned with being seen from behind. Also, amber LEDs were a fair bit more expensive than white and red LEDs back in December when I ordered these parts. My thinking at the time was that I would install the rear LEDs and eventually get around to replacing the front turn signals and running lights with LEDs.
However, now I think i will leave the front incandescent bulbs as-is. Why? After installing the new rear turn signal LEDs, the turn signals flashed at the normal rate. There was no rapid flashing. After thinking for a moment I realized that the front turn signal incandescent bulbs were providing sufficient resistance in the circuit, so extra resistors are not needed.
Moral of the story: If you only replace one of the two (front or rear) turn signal bulbs on a side of the car, you do not need an additional load resistor. (I did not do the circuit analysis, but welcome confirmation from anyone who does.)
Conjecture: I bought four load resistors under the assumption that one is needed per LED. However, if you replace all four turn signal bulbs with LEDs, I think you only need TWO load resistors. One for the pair of left turn signal LEDs and another for the pair of right turn signal LEDs.
21 - 40 of 81 Posts
