1 - 5 of 5 Posts
Has any one tried to use LED replacement bulb in there tail and brake lights.
Or any other place on the dash? or turn signals. I searched the site but could find no reference to this. I'm thinking it might be worthwhile as the light on the Duetto are not the brightest
· But Mad North-Northwest
If you're looking for brightness for external lights, retrofit LEDs aren't the way to go. They light up faster and run cooler but aren't as bright (at least, they weren't when I was looking a while back).
I've used them successfully for internal lighting on the Alfas, but again for cool operation and reduced power draw rather than brightness. The high-power interior LEDs are about the same brightness as the incandescents they replace.
I bought the LEDs from these guys:
LEDLight.com LED Lights, LED Lamps, LED Bulbs
Daniel Stern once told that he carries external taillight and signal lamps that are 40% brighter than stock. You might want to contact him to see if he has any suggestions.
Daniel Stern Lighting Consultancy and Supply
I would offer a different opinion- when we put the LED's on my friend's race car, the brake lights really, really popped, and were a lot better from a distance.
You have to get the right ones, though- so that the bulk of the LED's are pointing in the right direction.
One issue for outside lights is the turn signal relay- it uses the resistance of the bulbs for the on/off timing (which is why they blink faster when a light goes out), but the LED make the relay so fast, it does not blink. You need to replace the relay with the one supplied at the LED store.
Anyway, I liked them so much, I'll be putting them on my racer, too.
I guess we are talking for white leds only? Yes, in one straight ahead view they were great but what happens from an angle viewing? I feel that modern cars with leds use different lenses than in the old cars, perhaps with more light diffusion. More over, modern cars have a lot better stabilization voltage or current systems for power supply to the leds.You might need to set an array of leds in series which supplied from a 12V system to
handle the 12V, since each one led needs 1.25V ( or around that). Or, use the well known limiting resistor. In an old charging system which varies a lot in voltage, sooner or later some leds will be failed!
On the other hand, for flashing, there are on the market real leds which can be supplied direct from a 12V power source without any problem. I'use them in a race car, too, just for a warning light. And guess what? They were flashing devices by them self! I didn't gave them the chance for being really flashers bulbs, but since our opinions are sprayed here, why not? You can discriminate those flashing leds than the usuals from a black small material inside of them.
1 - 5 of 5 Posts
