1 - 2 of 2 Posts
Hey guys I hope you can give me some help. The banjo fitting right next to the oil filter is leaking on me. Does anyone have an idea what size bolt this is? I know it's larger than a 22mm. Once I can get the bolt off it should hopefully be a simple fix. Thanks
Boy that must be a big fluid bolt holding that banjo fitting in if 22mm socket is to small.
Besure it is not pressure check valve seal leaking that banjo fitting screws into if that is where leak is at.
1 - 2 of 2 Posts
