Hi all,
Im converting my early GTV6 to run on the more modern Milano 3.0 ECU with heated 02, 3 wire TPS and deceleration fuel shut off...I will also gain electronic ignition advance and loose the weights in the distributor.
I will need a new style throttle body with the 3 wire TPS castings, as the old throttle body wont allow mounting the TPS, because the new throttle doesnt have the idle adjuster (moved to the plenum) ill need a new style plenum also
if anyone has these laying around for purchase it would be helpful.
Also: I am looking for a distributor to do some modifications on my Motronic converted Milano...it DOES NOT HAVE TO WORK, only need the aluminum body and the spinny bits inside, the hall connector can be broken doesn't matter
Thanks!
I have a 2.5 Milano manifold in Ontario, if you are still interested. Got a pretty rough dizzy housing with "spinny bits" as well.
