1 - 2 of 2 Posts
Hi all
I need some help please. i am able to get hold of a pair of AF2 reground kent cams. the specs are;
426" lift
308 degree duration
Installed at 106 degrees on both inlet and exhaust as a starting point.
Can any one tell me please if these are a suitible hot cam for 1600 105.
Many Thanks
Mat
Richard Jemison
Kent Cams
Since it is a cam not on their site I suggest you call them and ask if they would give you the profile information (not data on the website) with that it is easy to determine application appropriateness.
However you would not want 2 of them on a small motor. If the 308 degrees duration is at .020 lift it is too much cam . If that is total off the seat duration the full profile will tell the story.
Tel: +44(0)1303 248666
Fax: +44(0)1303 252508
Email: [email protected]
1 - 2 of 2 Posts
