1 - 5 of 5 Posts
Vacuum lines, where goes what ?
Hello all,
just replaced the intake manifold rubbers from our '87 QV and while reassembling it all I'm confused where to put the vacuumhose from the ignition and where the hose that is coming from the camcover.
I included a picture, where does nr 11 go ? on the front of the camchaincover below the thermostat housing or the little sprout that's on the nr 1 carburetor ?
Thanx, Frans
normally 11 small hose goes on the manifold's rights up small oulet , yes just below the thermostat. I guess the vacuum hose from dizzy must go on the carbs
Yes, European with solex carburetors, no emissionstuff on it.
I got confused because the vacuum advance is now only acting on vacuum from nr 1 cilinder.
Guess the connection from the camchaincover flows just back to the crankcase ?
Frans
I dont know how its arranged on a 1987 euro, but on my 1971 1300 Spider this no 11 tube is simply connected to no 1 cylinder manifold (no vacuum advance ignition) to suck bypass gasses.
1 - 5 of 5 Posts
