as with everything.. there is a safe way to do this, and a unsafe way to do this......plastic dust in your lungs is just as dangerous.. ...a mask when useing 'lead ' or plastic is a good idea.... use power sander on plastic.. and it gets everywere and it floats in the air,,,much longer than ' lead '.. you dont 'melt
the lead, nor do you ' vaporize ' it.. it more like laying on soften butter....then smoshing it down into the panel and spreading it around.. and using power tools..sanders etc... its very easy to block sand it,,,and if you wanted to, as i do it,, i use dishwashing soap( dawn ) and wipe it onto the ' lead ' durring sanding... this way no dust... then when you are done.... just rinse off the soap... and no matter how you do it,, water will get under the plastic at some point.. plastic will not flex with the bodyshell, and all that micro flexing.. will allow waterin some form... vapour most likely to get under it,, and start the rust to start... the ' lead ' will flex with the bodyshell... use what you feel the best with...when i use ' lead ' i am allways outside..
