there is a weekens in the wireing harness, where it passes under the sterring colloum, the area has no rubber gorment, to prevent fraying, look under you dashm you wil see a buch of wires pass thru this hole.. easy fix, get a old bicyle inner tube( mt. bike is best) cut 2-3 strips about8" long, then cut the tube into a flat shape,,,, put these two rubber innertube togeather, and pass it under the wiring harness thru the hole, it will take a wee bit of work, not much room under the dash for use, fish it thru,, carefully make shure the the 2 innertubes are between the metal and the harness.
