Held please
ow at the final stages before media blasting, now stripping down bushes and ball joints/front suspension. Everything is off the car but I am struggling to remove the front discs, both screws removed however there is a plate in front of the discs which I cannot pull off, tried hitting/swearing and begging, any advice would be welcome?
Do you mean the wheel hub is the plate in front of the disc? You have to remove the wheel bearing nut and remove disc and hub assembly, then separate
That’s it.... remove the cap and there is a nut and split pin to remove....
Reactions: PSk
