Attached is a photo of the original (I believe) windshield washer fluid bag in my 1970 JrZ. The bag is cracked and I've had no luck in finding a correct replacement. The spacing between the mounting lugs is 140mm. The attaching clips for the bag are welded in place (again, I believe original). All of the bags I've come across (I have purchased three different bags from vendors) have narrower lug mounting spacing (120mm, etc.). As the car is being repainted I'm thinking of just grinding down the lugs and use new ones to match the currently available bags. Has anyone come across this problem before (I'd really like to stay with the original setup if possible)?
-John
Hi
Mine has a Mitsuba bag on it which I believe come from vintage Honda's and Datsuns.
It is definitely the 140 mm spacing.
I have the same need - was never able to find a Tudor bag with the correct spacing.
