I think John M has or is doing so...
I would think anyone would prefferr to have their cam grinded and welded to maintain the VVT as an option. Motronics showed 118ft/lbs of torque @ 4800 and [email protected] 5800RPM. The jetronics, torque curve was nothing, at all compared to Motronic (Jetronic: [email protected] and 118.8ft/[email protected]). Jetronic didnot provide a decent torque curve. I also want to point out these readings were with all accessories running on the 1991 Engine, take off the power steering option and AC option and you'll have lots more torque and HP compared to the jetronic.(a cam change from VVT to non-VVT for example)
Never. You exactly pointed out the issue with tuneability. Its not like you can hook a laptop to it and change the settings as you have the car on the dyno.But would you pull a functional L-jet to put in a Motronic system?
To me there wouldn't be enough benifit to make it worthwhile.
Even the chip is based on someone elses interpretation of what the stock configuration needs to get a bit of boost, but not neccisarily what a given modification or group of modifications would need. (a cam change from VVT to non-VVT for example)
Without total programmability, it's just a dead end waiting to happen if the swap is done to try and get more tunability than the L-jet :shrug:
Yes, but there are places out there (Jet Performance and Casper for example) who will reprogram the EPROM to the changes you made to the engine, bigger valves, bigger cams, equate a known increase in flow, which changes the fuel delivery demands. Believe me, I know I am being biased, but nothing is impossible when it comes to custom made mind setIts not like you can hook a laptop to it and change the settings as you have the car on the dyno.
Best Regards,
John M
Hi David,Yes, but there are places out there (Jet Performance and Casper for example) who will reprogram the EPROM to the changes you made to the engine, bigger valves, bigger cams, equate a known increase in flow, which changes the fuel delivery demands. Believe me, I know I am being biased, but nothing is impossible when it comes to custom made mind set![]()
Murray, the EPROM is just like the bios in your computer, it can be flashed/reprogrammed for anything you need. There are lots of places that can flash an eprom for any car to make it do what you want it to do, including rev limit...heres one for example: ECM/PCM ProgrammingHi Dave,
You can't reprogram the Montronic EPROM, either you buy a perforance chip to replace it or you can add a piggy back system to the Montronic that can control the spark and gas but even with those piggy back systems you can't change the factory rev limiter settings.
