This thread will be complete in 8 days from now. The Pro Street Kit will arrive Friday when I'll install just the coil, but in the meantime, figured I would do side by side comparison of the Pro Street and a MSD 7AL:
MSD 7AL-2: $559.40
Ignition Box Output: Capacitive discharge
Circuitry: Analog
Rev Limiter: Yes
Timing Retard: None
Data Acquisition: No
CD Voltage Output to Coil: 570 V
Current Draw: 1 amp per 1,000 rpm
Spark Output (millijoules): 160 Millijoules
Minimum Operating Voltage: 12 V
Maximum Operating Voltage: 18 V
Length (in): 8.250 in.
Height (in): 5.750 in.
Width (in): 3.750 in.
Ignition Box Color: Gold
Coil Included: No
Jacobs Electronics Pro Street: Cost $339
Circuitry: Digital
Rev Limiter: Yes
CD Voltage Output to Coil: 535 V
Minimum Operating Voltage: 7.5 V
Current Draw: 11 amps at 10,000 rpm
Spark Output (millijoules): 145 Millijoules
Length (in): 8.500 in.
Height (in): 2.500 in.
Width (in): 4.500 in.
Ignition Box Color: Blue
Coil Included: Yes
Coil Style: E-core
Coil Internal Construction: Epoxy
Maximum Voltage: 60,000 V
Mounting Bracket Included: Yes
Coil Wire Included: Yes
Coil Shape: Square
Coil Color: Blue
Anti-Theft Switch: Yes (I got that as an option)
Micro Throttle Activated Switch: Yes (I got that as an option)
"The Pro Street uses a high speed digital
processor to control multi-sparking and capacitive discharge
output. An adjustable rev limiter set by rotary dials is
included. An optional full throttle switch can be connected
that significantly boosts the Pro Street's output when you
need it most!"
My oppinion is that $ for $ Jacobs Electronics Pro Street is the best ($ to $) ignition system around!
MSD 7AL-2: $559.40
Circuitry: Analog
Rev Limiter: Yes
Timing Retard: None
Coil Included: No
Circuitry: Digital
Rev Limiter: Yes
Coil Included: Yes
Coil Style: E-core
Coil Shape: Square
Coil Color: Blue
need it most!"
