Could only post a few photos at a time, here's more
February 22, 2012
011George Willet
1615 E. Clover St.
Casa Grande, AZ 85122
520-374-2220
Cell 360-391-1620
Parts Inventory photo descriptions
001: Weber Carb parts, linkage arms, air horns for 40/45 DCOE
002: Bosch distributors and msc parts
003: Mirelli distributors and msc parts
004: msc air cleaners and parts for carbs
005: points, condensers, coils, etc.
006 and 007 Sun Distributor machine and electronic distributor adaptor, file folder on advance curves
008: work bench, bins and boxes of parts
009: Binboxes of transmission gears, mainshafts, sliders, bearings, special bolts, shims, etc. three sets of .85 fifth gears.
010: Two barrel manifold and Weber carbs and pieces to use on a 1600/1750/2ltr.
011 thru 016: Bin boxes of carb and Spica linkage, assorted Weber carb supports, lug nuts, tie rod ends, bushings, bearings, seals, special bolts and on and on.
017 and 018: 105 and Super side marker lights and sockets.
019: Alfa-Power Camera mount assy.
020: 1300/1600/1750 remote oil filter adapters, with gaskets.
021: bins of valves, springs, retainers, keepers, shims; timing gears and chains; drain and fill plugs; temp/oil/fuel senders; thermostats and covers; and on & on.
022: Box of bags of special engine bolts, 1750 and 2ltr cylinder heads, msc cranks.
023: 1600/1750/2ltr head and engine gaskets, box of bagged msc gaskets.
024: Full set of valve shims in the Alfa box with sheet of metric and fractional sizes; dial indicator fixture to check shim thicknesses.
025: assorted Weber jets, air correctors, emulsion tubes, etc.
026, 027: 1600/1750/2ltr pistons, rods, liners.
028, 029,030: assorted flywheels, ring gears, clutch plates, discs, Shankle antiroll bars, motor mounts; and so on.
031 and 032: Shelves of 105 oil pans, 4 and 5 speed transmission assys and cases, bell housings; Spica air boxes.
033: Totes of assorted parts: shocks, springs, spring pans, horns and horn buttons, emblems, sunvisors, throttle and “choke” lever assemblies with cables, turnsignal/headlamp switches. 105/115/116 doorhandles. Valuable stuff off of salvaged cars.
034: 2ltr engine from a spider( pilot hole in the crank)
035 thru 040: Boxes of things like switches/knobs/levers/light sockets/speedos and gauges/steering wheels stock and racing with adaptors/Super door inner and outer handles/window crank handles/ window regulators and vent transmissions.
041: blocks and short blocks; one short block is a European 1600 from a 116 car and has a nitrated crank.
042: box of GTV and super e/brake cables; tach and speedo cables, necessary brackets and treasures.
043 and 045: fuel and oil filter assemblies; exhaust pieces, flanges and pipes; three GTA exhaust manifolds and pipes with a collector to modify headers to fit around pedal boxes, a project in process; muffler.
044; more transmissions and bell housings
046 and 047: Books and manuals for Alfa engines, transmissions, Spica tech manual from Alfa factory; Milano shop manual, GTV6 manual; several Competition Advisory manuals from Alfa; books on, yep, Alfas.
048: Books on Weber carbs, books on how to set up distributor curves; suspension design; and more
049: programs and manuals on suspension and engine design and what will changes accomplish, along with download of Alfa build files. Years of work.
050 and 051: Document files on suspension set-ups; transmission ratio spread sheets; Cylinder head porting and design; engine building files. A wealth of years of Alfa (and general) knowledge to go on a disc(s).
