I have an ITG JC50/S/75 air filter on my GTV. I used air filter oil on it that I got from Coast Fabrication, where I bought the filter about eight years ago.
After neglecting the filter for far too long, I washed it as per the No-Toil cleaning solution directions ... and watched as the outer layer of the foam filter crumbled and went down the drain.
My two questions for other foam filter users are:
1. How long do you expect a foam filter to last before it needs replacement?
2. Do you find that foam filters last longer when you use oil on them or when you don't?
Given the cost of these things, I want mine to last as long as possible.
