The defrost fan did not work in my 79 spider so I went about the 5 hour job of removing the unit. It looks like water pooled at the botom of the plastic housing and submerged the motor. Looks like no drain hole exists at the bottom.
Soooooooo. WTB 1 each blower fan motor for a 79 Alfa Spider. Or trade for......
Water pump for pre 79 spider with tach gear
tach for same cable for tach for same
You've got a deal (if someone else hasn't already responded). I'll box it up with the alternator I'm sending you. I'll test it first. You've got the right idea, drill a drain hole in the bottom of the housing. Are you sure your heater core doesn't have a leak?
Bill Sinclair
Bill:
System up to full pressure recently with no leaks. Inspection shows no sign of leaks.
