Looks like for a relay. Maybe the fuel relay. I think yours is bypassedThis 3 wire connector is not plugged into anything in my 83 spider. It is near the ECU. Should this be plugged into something?
if your ECU is a Bosch #0 280 000 206This 3 wire connector is not plugged into anything in my 83 spider. It is near the ECU. Should this be plugged into something?
And I am guessing that is also when the solenoid activated VVT came out in 1985. Yes?if your ECU is a Bosch #0 280 000 206
and that connector has two pins (but 3 wires), then its the "high altitude jumper"
you jumper it when you get really high......
...like a few thousand meters high...
the later 85 or so on, had a different ECU # and a variable altitute comp device (like in photo above) and then that connector would be 3 pin, 3 wire.
Yes, this connector is a 3 wire, 2 pin. So sounds like mystery is solved, thanks!if your ECU is a Bosch #0 280 000 206
Edit/s: it is I believe at 4000 foot up, that one should jump the connector.
And the alt. comp. device likely appeared first in 1984, not 85.
'84 Spider, alt compensation device present, centrifugal VVT (no solenoid).for example, Eric's '84 spider has the alt comp device.......which begs the question does his '84 also have a solenoid VVT??.....
Eric, what say ye?
