1 - 20 of 29 Posts
I have had this for a long time, assumed it was an Alfa part. Looks similar to the parts under it in the 3rd photo? Is it an Alfa part, if so what?
As long as we are playing this game a bunch more parts mixed in with alfa parts that I am not sure of. Recognize any of these?
Bottom left alloy maybe Alu or zinc bracket that is riveted to step nose head light mount that the chrome ring is held to.
Another photo. I always thought the black plastic was from a heater box? The light lens from a 50s Alfa?
Discussion Starter #12
Ken, Good eye indeed. Closeup photo and drawing with #s. The hole is threaded.
Discussion Starter #13
There are no #s on the small lens. So maybe not Alfa?
Discussion Starter #15
Weber parts? The first photo, 26 stamped in part. No number on the other metal part in pic #2. Pic #3 labeled Weber choke linkage nuts and bolts. I don't have a weber equipped Alfa anymore.
Discussion Starter #16
The correct terminology is ''26mm choke'' and ''auxiliary venturi'' in my last post.
Look again carefully at the Aux Venturi as they may have a light stamping such as 4.5.
Ken
Discussion Starter #18
You are right, after a bit more wiping and looking 4.5 is stamped into Aux Venturi. This and choke are about 38mm OD.
You guys are good.
On another board, someone asked the similar question "Name this bolt.", and got the answer of, "Bob. Bob the bolt.".
I guess there are stupid questions, but I do like this ID game.
1 - 20 of 29 Posts
