Question
Can any of you advise me on whether I should paint the badge section of my GTV C-pilar before affixing a new badge to it?
And if so, what type of paint you would recommend for this?
(Photos attached at end of post)
Background
I removed a gold clover badge from the C pillar of my GTV 2000 so I could put a model-correct serpent badge in its place. I used a plastic auto trim removal tour to pry off the badge. The adhesive under the badge was so strong that it pulled a section of paint off the body. Fortunately, it only damaged an area of paint that will be hidden from view by the new badge.
I want to make sure that this area of the body will not be at risk of rust from any moisture that seeps behind the new badge. Part of the area with paint loss appears to be safely covered in gray primary, but there is an area where even the gray primers came off that is brown. While I don’t think that brown area is body panel raw metal, I’m not sure what it is, so I can’t tell if the panel has sufficient protection.
Any advice about whether it’s safe to leave this as is, or it needs a primer and/or finish coat of paint for protection before attaching the new badge would be much appreciated.
Question #2: Adhesive for new badge
Finally, if anyone has advice for the best adhesive to use to attach the new badge so it holds to the car, but doesn’t rip off paint if I have to replace it again in the future, I would welcome your suggestions. At the moment, I’m debating between these products:
— 3M Super Strength Molding Tape for autos (3M product# 03614)
— 3M Black Super Weatherstrip Adhesive (3M product# 08008)
Photos attached
I’ve attached photos that show the following:
— My C-pilar after removing badge, showing the area where the paint was pulled off. I’m guessing that the two gray areas are layers of primer, but I don’t know what the brown area at top center is.
— Back side of the gold clover badge I removed, showing the paint that was pulled off the body.
— Back of new silver serpent badge I will put on the C-pilar. It has a flat back, with a thin raised lip at the edge. It’s not one of the badges with a recessed area in the middle.
So many ways to do this
Simplest, yes you need to seal the area so it doesn’t rust and so that moisture and air don’t wick under and into the filler/bog that is present.
If it was me, I’d strip the whole car and repaint (jokes.. don’t do this)
You just need to seal it. I would get some clear epoxy paint and dab/paint it carefully on so it doesn’t run down the C pillar and rear arch, but ensure it gets absorbed, wicked into and under the filler/paint to seal it
Leave it to dry and set for twice as long or longer than recommended, then just used some sikoflex or whatever brand badge glue/silicone is available and appropriate in your country/region
** using the location info on your profile will help people help you with more specific info, even a country helps
Craig, many thanks for your reply and your detailed recommendation for painting the body panel and adhesive for the badge. Also, thanks for the tip that I add my location so people can offer more specific info, which I've now done. (I live near San Francisco in the US.)
Paint it first and use a good one like 2k Epoxy. Then scruff it so that the glue adheres. With time adhesives can become permeable and moisture will do its work.
An extreme case, but this is what happened to roofs covered with glued vinyl. Reason was the absence of paint.
If it were mine I'd use an aerosol primer brush on some high solids paint afterwards, once fully cured use tiger seal to bond on the badge. Tiger seal is the type of rubber bonding used to secure modern windscreens so is very strong and water tight. Only problem you'll have is removing the badge at a later stage. If you do it this way, use a big dollop in the centre of the badge and tape it in place for 24hrs.
