Can anyone come up with a photo of the internal fuel pump in the sending unit assembly?
The bracket (the thing that somewhat resembles salad tongs when disassembled from the sending unit) is not symetrical and it makes a difference which way it faces in relation to the sending unit. I can't seem to determine the correct way to orient the pump assembly in the bracket. When I install in the tank, the bottom of the assembly hits metal - and that can't be good with vibration; or it prevents the sending unit float from moving its full range.
Dale
'82 Spider w/ F.I.
Dale
'82 Spider w/ F.I.
