I was able to get some o rings from difatta (thanks for the help), so I am attaching the bracket back onto my engine. I do not see any torque specs for the bolts in the workshop manual. Is there a torque setting or is it best guess? Thanks.
What size is/are attaching studs/bolts? On the 12v V6 engine the studs to mount rear engine mount to the engine block are M8x1.25 coarse threads with 13mm Hex head nuts. That being said about 18.6 lbs ft. (max torque 28 lbs ft for 8.8 grade hardness M8 bolt) Metric Bolts - Tightening Torques
