1 - 20 of 21 Posts
Anyone see this before:
http://deanwcains.smugmug.com/photos/165829156-L.jpg
It's out of my 42,000 original miles '74 Spider. The distributor is a Bosch 041 JF4 converted to an optical trigger, so the distributor has virtually no friction or binding.
It's a first for me. And, if anyone's wondering, you can get the oil pump out by just removing the bottom section of the sump. Each of the 3 oil pump retaining bolts requires a different tool, but not a bad job, and much easier than pulling the whole sump off or pulling the engine out of the car.
Oil pump failure
Oh Yes! My favorite failure of the "new and improved replacement pumps"!:rolleyes:
Here's what has happened. In the good (read :eek:old) days, the pump shafts were of a high quality steel and hardened at the dist. end, then ground straight, lightly (read:) L I G H T L Y) totally hardened, for resistance to galling where they pass through the pump bottom.
NEW and improved shafts are induction hardened all the way through, causing some shafts, (depending on the alloy quality), to become brittle enough to fracture at the drive gear pin hole. This drilled hole acts as a stress riser, and "ker-snap!":eek: "curse curse curse" in the distance:mad:. The newest after market replacement pumps have also failed in this way with racers:(:(. Try to find an older NOS pump, or excellent used one for replacement.:cool:
:DGordon Raymond
Gordon, how does one tell the pumps apart?
I installed a "new" oil pump in my wifes spider at the over haul. I now have about 7,000 miles on the engine. as evidenced by this thread, I am ready to drop the pan and install one of my older and tested oil pumps . Nothing worse than being stranded and no way to repair it.
Christopher, the ones you don't want are the ones that look like the pump in Dean's picture. Just tryin' to hep a bit.
I was just looking for some type of identifying mark to help me. I have a new AR pump still in the bag. I might opt to install that one just to be on the safe side. It isn't that hard to drop the pan, just more of a pain to have to do it.
I wish I knew how to help you, christopher. I'm fairly sure there must be some tell-tale mark or tempering colorization left on the shaft, but I have no idea what it would be. I used to live next door to a fellow who owned what may have been Oakland California's last heat treatment shop. Among other things, he did case hardening of steel shafts. He might have known how to tell the difference, but I don't.
:DGordon Raymond
Hey Gordon:
I'd bet that pump from my '74 is the original pump from '74. AFAIK this motor's never been opened, even for a head gasket, and those 42,000 original miles are an accurate number.
In any case, I've got a stock of three other "old" pumps, so that's what I'm going to replace it with.
I was just poking at Christopher a bit. The characteristic of your pump that makes it undesirable is not that it might break, but that it _is_ broken.
Michael
Oil pump failure part II
Hi Chris,
The latest replacement pumps have a sort of carbide blasted finish on the body. The aluminum is darker in color, not shiny like older pumps. There is a "web" missing from the triangular area that bolts to the front cover. However this is the body of the pump and that part is GOOD! the shafts that I've seen fail, have no color hardening marks just below the upper guide bearing that runs in the aluminum front cover tube, AND the larger dist. drive. Good new ones, have a bluish hardening marking below this bearing area AND EITHER the small or larger dist drive top. Again, there is nothing funny about the newer housings. Only the shafts may be questionable. I have in my hand a new bodied pump with steel internal gears, and an old (looks like 101) shaft, put together by a racer. He possibly broke the shaft that went with the new body. A year ago I was thinking of making up a dozen or so GTA shafts, until I found how expensive they would be due to the multiple machining and hardening steps required to guarentee they would be tough, but not break. Keith Goring was also looking at having some made up at the old euro MIG plant, but also ran into the "cost vs who will pay that much" problem. The problem with making up these shafts as an individual, is the possibility of failure either in an expensive GTA engine, or other racer where a failure could result in injury!:eek: I have a note somewhere from a racer that broke two new pump shafts in qualifying:confused:! The combination of heavy weight oil and high RPM, can cause sudden failure. Usually (not always) the dist not turning shuts the engine down before the lack of oil pressure does:rolleyes:. The closer the gear to housing, both radial and axial tolerences, the higher the load on the drive gear and pin. The pump bottoms are often lapped to decrease the axial play for more pump volume:cool:. There is probably only a slight difference between "safe" tolerences and serious loading of the pin area in modified pumps:p.
With normal street pumps, they should last as long as a good engine rebuild, IF oil is changed regularly, and high RPM with cold, heavy weight oil is avoided. All this is based on a properly heat treated shaft of a uniform alloy:). These shafts must be hard on the surface to avoid wear, yet have some internal flex to resist this type failure. Just my opinions based on observation;). :DGordon Raymond
But, why would the shaft snap on the distributor drive side? At least in my application, there's nearly no friction from the distributor, because there aren't any points - only an optical trigger. If I give the bottom of the distributor shaft a good twist by hand, it will spin freely for at least a few revolutions, so it's pretty loose.
1966-2013
But is there really no friction?
If the dizzy is anchored down to the point where it sinks in a littler further onto the drive then it may very well bind on it's bushes a bit, which in turn would create drag on the drive shaft.
The rotor and cap are built to withstand a bit of up/down play (or there would be a lot more cap and rotor replacements) so it may not appear to bind in the conventional sense (the rotor still turns, the cap still fits on) but the guts can still be tighter than normal.
It's a bit late now as yours is already busticated, but upon replacement, see if there's a tiny bit of play in the dizzy shaft by pulling up on it after install. (shouldn't be much obviously, but it should be there)
If there's not, then chances are the dizzy is actually crushing down on the drive shaft making for a bind all it's own. (past experience with that can allow me to tell you with some authority that if you do that to a Ford smallblock, the drive shaft will bend or the part on the oil pump or the dizzy proper where it engages will break off pretty consistantly)
Or, you could strip down the dizzy shaft and check for excessive wear marks on the bottom of the housing where the drive spline abuts.
Discussion Starter #13
Perhaps, I'll have to see what it feels like with the replacement oil pump in place. As far as I recall, and it's been a while since I've pulled/installed the distributor, I think it always seemed a bit loose, as if it was almost too short to engage its key fully, especially with a fresh o-ring seal in the timing cover. You may very well be correct, though, and I'll check carefully when the new parts are in. Thanks.
Believe it or not....I had a dream last night about my alfa oil pump...specifically the pressure relief valve.:confused::D
Best Regards,
John M
Why oil pumps break
I can't read the procedure that Papajam posted, but I'll bet it addresses this problem:
The mounting flange for Alfa oil pumps are at an angle relative to the shaft. There is a fat O ring between the pump's mounting face and the surface it attaches to at the bottom of the front cover. If you simply tighten the 3 bolts that hold the pump to the cover, you will often find that the shaft won't turn easily. The problem is either that the parts either have some tolerance in the angle between the shaft axis and the mounting surfaces, or that the pump "rocks" a bit on the O ring as it is tightened. Either way, this misalignment puts a bending stress on the shaft, the hole where the pin goes is the weakest point, and it will fatigue. This generally happens within the first few hundred miles after a pump is installed.
Sure, new shafts may fatigue more readily than old ones - I'm not saying the heat treating stuff isn't true, or doesn't contribute. And, no, I can't explain why a pump would die after 40,000 miles (maybe it was only slightly misaligned)
But, the best way to install an oil pump is with the front cover off the block, tightening the three bolts slowly, and checking that the shaft will turn freely. I put some loctite on the bolts, and tighten them just snug - not super tight - tinkering with the relative tightness of the 3 bolts to ensure that the shaft is turning OK.
If you engine is assembled, in theory you can use a large screwdriver in the distributor drive to wobble the shaft within the lash of the drive gears to ensure that it isn't binding. I have never tried this - it would seem to take two people - one standing up feeling the shaft rotation, and one on his back under the car tightening the oil pump bolts.
I learned about centering the oil pump when I first started wrenching on Alfa's. I am sure others can chime in on what they do, so this is just my opinion. I install the oil pump and the three bolts. As I tighten down the bolts, I spin the drive shaft making sure the pump gear doesn't bind, until the bolts are all the way home. If you just bolt the pump down, chances are it isn't centered, putting some axial load on the shaft.
Uh-oh. Does this centering issue rear its head for the V6 also? I didn't do anything like this for my wife's 164S engine when I reassembled it. It's not an attractive thing to have to pull the engine back out, but better than breaking an oil pump, I guess.
Michael
1 - 20 of 21 Posts
