Part 1,
Removal
To be continued...
Removal
- Remove the front of the plastic bezel.
- It is held in place by 3 tabs at the top and small hooks at the bottom.
- Gentle press on the marked locations and pull it out just a tiny bit. We are not removing it yet, just freeing up the clips. Once all the clips are free the top part can be pulled farther out. This in turn will free up the small bottom hooks. Carefully wiggle it out without scratching the glass.
- Take out the 4 screws holding the cluster in. They are at 8:30, 10:30, 1:30 and 3:30 locations.
- Place the towel over the steering wheel and pull the cluster out ever so slightly. (An inch or two)
- Disconnect the top centre connector first. Press down on the middle tap to release the safety and gently wiggle it out.
- Now you can move the cluster little more but still pay attention as those wires are short. Disconnect the remaining plugs in the same way as the first one.
- Take the cluster out. Right side up first on the 45deg. This way the odometer pin will clear much easier.
To be continued...
