What lights should turn on when the ignition switch is turn to ON. I get four lights initially, TEMP, Brake, OIL and BATTERY. The TEMP and BRAKE go off after a 10 or so seconds. The OIL and BATTERY lights go off once the vehicle is started.
My Spider failed inspection because the parking brake indicator light does not come on when the brake is set. I have checked the switch at the handbrake and it is functional. I hate to remove the dash (again!!) and wondered if any other lights should be coming on as a "check light" function before I tear into it.
Thanks.
Thanks.
