1 - 5 of 5 Posts
Just confirming what I think I found throughout the internet: can my 1986 GTV6 use Milano inner tie rod ends? I think I just need to remove the steering damper.
One more thing. My steering damper was not functional at all. Zero dampening = useless, so I didn't re-install it. But you do have to re-use it's oblong mounting bracket/plate.
You may want to check yours.
As OSIDEDM says: you can use Milano inner tie rod no problem.
You can also discard all the steering damper and parts IF you source and install a longer steering boot on the passenger side. I've done this several times, no problem. Otherwise you can keep the parts as stated to re-use the unusual boot. A Milano boot fits, but its a stretch. I used a shock absorber dust boot most lately and it was a nice fit. O'Reilly supplied - it was a fairly generic part.
1 - 5 of 5 Posts
