In the middle of a conversion , question is I am using a milano L jeronic ecu and harness , will it fire motronic injectors from a 164? Thanks for any input.
I doubt it too. The jetronic injectors are low resistance (that is electrical resistance measured in ohms). The Motronic injectors are high resistance (again speaking in terms of ohms).
Bye
The flow might be different. I would say use aftermarket something with a computer inside.
but any ECU that can drive low-Z can drive hi-Z but not the other way around.
so it will not fry a l-junk driving a hi-z motronic. but the l-jet is a very crappy system.
just about as bad as it gets. it is super simple so it is kinda reliable but over all it it junk.
moving back from a motronic to a l-junk is a big step backwards.
there are so many aftermarket ECU's to use now I would say get one with a good rep. or at lest one you local tuner likes..
