I have an 83 Spider with an injector problem.
#2 cylinder does not fire well at idle, but does seem to kick in as rpm's increase.
I sent all injectors out to be cleaned, and have just reinstalled them only to find out I have the same problem.
Does anyone know what else would cause an injector to not run properly?
Also, the car occasionally refuses to run at idle.
When I disconnect the throttle position switch, it seems to fix the problem.
I replaced the tps with a used part, and it still does the same thing. Could I have ended up with a second bad unit??? Or, is there something else wrong...
Thanks for the help,
Dan
Dan
