My 1994 LS gives me irregular readings from the voltage meter. It shows around 13 volts sometimes, and under 12 at other times. I have checked the output at the alternator,and battery, and it is reading 13.8 volts. Just recently I used a different key, and it was consistantly showing 13 volts, but at times when I started it the CD player would not come on, or could not be turned on. If I stopped it, removed the key and then started it everything would work. I tried the other key today, and everything always worked when I started it, but the voltage was at times showing below 12 volts, and other time 13 volts. I am thinking the ignition, any suggestions.
Moderator
Do you mean ignition switch if so you maybe right?
Moderator
Get one for 91-93 from somebody like www.difatta.com as price about half of one for 94-95 and you get lock sets for doors and trunk with it. Search for my post on it with parts numbers.
Moderator
Is it just me or do there seem to be a rash of ignition switch issues with the 1994 and 95's lately? I guess 12 to 13 years appears to be the life span of these components. Hopefully my replacement switch is good for another 12 to 13 years.
Jeff
