Firing order is 1-3-4-2. The rotor turns clockwise when viewed from above. Take the spark plugs out then turn the engine in the forwards direction (put the transmission in 4th or 5th gear and roll it forwards. Note when #1 startes its compression stroke (your finger over the spark plug hole will be pushed away). Slowly roll a little bit more until the pointer at the bottom of the water pump is aligned with the 'P' mark on the crankshaft pulley. This puts the engine with the #1 piston at TDC on compression. Note where the rotor is aimed. That is the location in the cap for the #1 plug wire. Install the other wires in the firing order.
Spread rat poison in the garage or get a hungry cat.
