Ok guys, my problem continues.
Firstly thanks papajam for the excellent wiring diagram.
So, using contact cleaner and a tiny wire wheel drill attachment, I cleaned all the fuse box contacts (including the two on their own to the left). I then put in new fuses througout. Still the same ?. To clarify the problem, here gos...
I have attached loads of photos to help. Firstly using an electricity meter, there is a permanent 12v coming from the red wire into the back of the ignition switch. When I turn the switch to the first position, no power is coming out the back of the switch to any of the terminals (except the red). Surely that's not right ?!?
When I bought this S2 a few weeks ago it was a non starter and somebody has clearly been playing around under the steering column. There are two further black wires coming out the front of the switch and one of these is not connected ?!? (See photo). Also there is one red and black wire hanging down loose, which is peramently live (eek!). The only terminals I can see missing connectors is some sort of white relay? above the steering column (see photo)? Now having said all that, when I turn the key to start, some of the dials start to work, the starter turns, a spark is being delivered but no fuel is coming from the pump. I'm no electrician, but surely when you turn the key to the first position, electricity should be coming out the back of the switch and going to many components including the fuel pump?!?
Are the wires in the right place at the back of the switch?
Sorry this is so long winded, but any advice would be greatly appreciated.
Many thanks in advance.
Phil
