1 - 20 of 39 Posts
I had the recent "pleasure" of replacing my ignition switch. It wouldn't have been too bad a job if not for the locking bolt removal.
Honestly, we should be able to meet that engineer and ask "just what were you thinking of when you designed this?"
As you know, if you have found this thread that the locking bolt is for lack of a better term, "a breakaway bolt head". Meaning that once in place you continue to turn the bolt head and it snaps off. Ya, it snaps off on purpose!!!!!!!!!!!!!
So you are left with a headless bolt. Not only that, it is literally located 180 degrees on the other side of the steering column. So you need mirrors and blind feeling around to find it. Unbelievable!
When its time to remove the ignition switch, in today's times, you use a dremmel to cut a slot in it and work its way out. I would love to know how Alfa thought this could be done without the dremmel. You can't get a drill back there.
Here is the cut broken bolt seen just about centre.
Auto part Engine Pipe Exhaust system Metal
Even after cutting the slot, it wasnt easy to get out. I read all kinds of posts that say it was easy, but not mine, oh no, not mine. I broke to srewdriver tips to get it out.
Ring Finger Jewellery Fashion accessory Engagement ring
As I have read on the BB, its better to install a bolt or the kind for the next time. So I found this hex head bolt and it will be way easier the next time around. Thought I would post the dimensions for anyone searching.
The appropriate size is M6 x 1.0 x 20mm
Label Receipt Font
Metal Fastener
Automotive lighting Auto part Nail
Hope this helps.
Vin
isn't it odd how working in a mirror image is so darn difficult for the brain to handle....
I used a mirror to do my heater valve and it sent me nuts, till I got used to thinking backwards;)
Good info Vin, thank you.
Even though I knew I was looking in the mirror, my fingers and hands still would go in the wrong direction!
Glad its done.
Vin
Reactions: maseratiguy
Theres a reason its called a security bolt. Without that bolt back in the day it would take all of 3 to 5 minutes to rip the plastic cover off, unscrew the bolt and hot wire it.
All you have to do is take a short center punch and grind the end so the point is on the side and tap it into the head of break off bolt. Once its loose about half a turn you can easily unscrew it.
Reactions: misterjagman
I always wondered why they went through the trouble on my '69 Giulia. Yes, you can rip the plastic cover off and the bolt will stop you from taking out the switch, BUT.... you can just pull the wires off the back of the switch and connect them, or just touch a screw driver to the right ones, (my Giulia only has three wires) and it starts.
You won't get very far with the steering column lock engaged. Which is the reason for the bolt. It saved our 73 spider from getting stolen back in the mid 70's. They had gotten it hot wired and made it to the middle of the street it was parked on. Before the lock engaged.
I have done so many of them I could do it in my sleep ...use to put the old bolt back in so I saved the cool looking new ones.
Reactions: alfabeach and ghnl
Does your ignition switch work sort-of? If so, it may prove easier to install a relay to take the electrical load off the switch.
When I changed out my ignition switch, I unbolted the column housing and removed the whole thing as an assembly. That made removing the anti-tamper bolt easy. Other than having to remove the one-piece Enbloc knee bolster, it wasn't too difficult.
After pulling the steering wheel and taking off the combo switch there are a couple of bolts in the cabin that hold the housing to the chassis:
Motor vehicle Automotive design Automotive exhaust Automotive exterior Bumper
Automotive tire Motor vehicle Gas Bumper Rim
Hood Automotive design Automotive tire Automotive lighting Vehicle
Then out in the left front wheel well, three nuts need to be loosened so the column can tip down in the cabin and be pulled out.
Motor vehicle Automotive tire Automotive lighting Automotive exterior Rim
Motor vehicle Automotive tire Automotive exterior Bumper Gas
1683889
All you have to do is take a short center punch and grind the end so the point is on the side and tap it into the head of break off bolt. Once its loose about half a turn you can easily unscrew Hello Jim, I just happen to be removing my ignition switch and ran into a snag. First time doing this. Security bolt I was lucky I found a Phillip screw in there. However, I pressed on the top push button that holds the inner workings and all that came out. Casing is still stuck in there and not sure why. Pic, any advice would surely appreciate. Hopefully I didn’t mess up too bad.
Wrong screw.
Look at the picture in the first post. The silver dot you see surround by black. That is the security bolt.
I realized that a few minutes ago, I took a (picture) attach of it with a mirror. Only thing it’s not even flush but sunk in to the hole it’s in. Looks like someone’s been on there already
Is that rounded bolt once tampered and top broken off, is it supppose to be sunk in like that past the metal inside hole from factory. Sorry, Pic I sent not too good. What’s the best tool there to cut a slot?
1 - 20 of 39 Posts
