1 - 2 of 2 Posts
Hello
i do want to check my coil for proper working order.
Does anyone have the correct numbers for the resistance of this coil?
And if so where to I have to measure it?
I do have a connection spade signed +B and a spade signed D and the center where the ignition cable goes to the distributor.
Thank you
Bernhard
Measuring the resistance of the windings will only tell you if the coil is alive or dead. You need a high voltage insulation tester to determine if it will work properly. If your car revs ok and does not have a high rpm misfire then the coil is probably OK.
1 - 2 of 2 Posts
