What is the correct name for the above? I'm referring to the idle controllers where the arm has a screw type drive, so that it increases the idle slowly and closes the same way.
Meaning, it is not an on/off solenoid. I had the correct term recently but for the life of me, can't think of it now.
If anyone reading this has installed one for carbs - especially DCOE's - what brand/model did you use?
I really want to hook one up as compact as possible to go on when I turn on the A/C. It would be nice if it doesn't require a big hole for mounting. If I can find what I want, I'll be mounting it on the end of the firewall cable bracket next to the cable - so thin is good.
If necessary I'll go shopping at Pick-A-part.
