Can I confirm that a pair of cams I pulled are definitely S cams either by the engine number or the markings on the camshafts? I just want to make sure before I go to the trouble of installing them.
Thanks.
An 'S' engine will be stamped with "AR64301 engine #" at the block below the distributor. 164L and B engines are stamped "AR06412 engine #"
On the cams, you won't be able to tell S from B/L based on any markings or casting numbers on the cams. Only way to tell for sure is to measure the lobes.
While a used S engine is almost guaranteed of having S cams, if the history of the engine is unknown, there's always the slight possibility that heads have been swapped in the past - best to verify cam lobes if you want to be 100% sure.
Joined Dec 30, 2003
Discussion Starter • #26 Jan 2, 2010
Identifying 164 12v cam shafts
http://www.alfabb.com/bb/forums/milano-75-1987-1989/160394-identifying-164s-camshafts.html#post832489
All 12v V6 164 cams:
L/H cam 3033 is longer and has notch at rear to drive 164 distributor and timing mark on #2 bearing journal same as GTV6/Milano.
R/H cam 3031 shorter cam and timing mark on #3 bearing journal same as GTV6/Milano.
164B/L intake lobe height 9.1mm (0.360") exhaust 6.4mm (0.250")
164S intake lobe height 10.1mm (0.400") exhaust 6.4mm (0.250")
I have a set of 164S cams that also have a B698 stamped on end of R/H cam amd B698 stamped on shaft of L/H cam.
Thanks so much, guys, I think I have the S cams. All things point to that.
Does anyone know the measurement of the total intake lobe? That is, including the base circle. It's tough to measure just the lift with simple calipers.
Now the tough question: how much power/feel will I gain on my 2.5 with these cams? I know not much but will I feel a difference?
164B/L intake lobe heel to toe measurement 36.90mm
164S intake lobe heel to toe measurement 37.50mm
164B/L/S exhaust lobe heel to toe measurement 34.10mm
Part numbers:
N° P.N. Description Features Mod. Q. Notes Col.
1 60540619 CAMSHAFT (SN) V1 L/H 164B/L
1 60534722 CAMSHAFT (DS) V1 R/H 164B/L
1 60548164 CAMSHAFT (SN) V2 L/H 164S
1 60548163 CAMSHAFT (DS) V2 R/H 164S
The measurement of the 164S cam intake lobe from heel to tip of toe is 37.50mm.
The measurement of the 164S cam exhaust lobe from heel to tip of toe is 34.10mm
The measurement of the 164B/L cam intake lobe from heel to tip of toe is 36.90mm
The measurement of the 164B/L exhaust cam intake lobe from heel to tip of toe is 34.10mm.
Part numbers:
