Wheel Studs and Studettes
I have 2 each 95 LS. On car 1, I have borbet Type C, (I think), definitely alloy, with the following embossed into the wheel
7J x 15 H2
KBA 42383
C70535
On car 2, I have borbet type A, chrome plated steel as near as I can tell, with the following embossing
A70525/1
KBA 41732
LK (embossed) with a stamped "981"
ET (embossed)with a stamped "25"
Who can help me decipher this? They are both 5x98 , no problem mounting.
I have a few questions
what size tire is supposed to go on these (obviously 15" but profile/width?)
What size spacer is supposed to be used? I am using the standard Alfa spacer (about .125" thick) -- is this correct?
What length bolt is supposed to be used ? The Type C's have to have a shorter bolt (they bottom out).
Sorry for all the questions -- I am trying to figure out what to do here as I need tires; have been using 195/65's OEM type but on the wheels they look a bit odd -- the outside edge of the tire seems to be nearly on the same plane as the outside rim edge -- just seems weird to me
I need more smarts on this ! Thanks !
7J x 15 H2
KBA 42383
C70535
A70525/1
KBA 41732
