I've recently purchased in 1974 Alfa Romeo. I believe it's a spider. The air cleaner says 2000 iniezione spica.
Supposedly the motors been completely rebuilt but it wasn't put back together again and it needed quite a few parts. I've got most of the parts and is mostly together and in the car. I thought when I started putting the motor together that should double check timming marks.
Question one, On number one cylinder, top dead center and both cam lobes pointing outward. The passenger side, right hand camshaft is a 16th of an inch off of the line. I think an entire tooth on the chain would move it much further than that.
Second question is does anyone know where I can get the tachometer gear? It goes in the motor and I believe has the timing pointer on it.
The third question is the manual says that the distributor, when on top dead center number one cylinder, that the rotor needs to point towards the front of the car. Does that matter as long as it's timed ? So instead of front it's pointed up, so number one wire would go up instead of to the front? The manual says it matters to the oil pump? I'm not sure y it would matter though.
This car is a little different than anything else I've worked on. Suggestions would be greatly appreciated.
Once I get those things figured out I need to figure out the smog pump and the holes in the exhaust manifold. There's nothing there to hook the smog pump to
