Of what appears to be hydraulic fluid on my drivers side floor. Brake reservoir is low but no leaks apparent from the master. Could it be leaking into the booster then into the car? Herb
Regardless of the model or make for that matter, if the Master is leaking and the booster is leaking, you have no brakes and the fluid is getting sucked into the intake.
Unless of course the Alfabb has a hydraulic leak. Then you are in the correct forum.
Herb in Colorado... I totally get that. :beta1:
