While disassembly a new-to-me 1973 GTV I found what looks like polyurethane t-bar thrust washer position fitting on either side of the bushes. Not one each side, but two on each side. They are severely deformed.
The image below (not my car) has arrows point to the where the washers were located on my car
I haven't seen this before except in this one image I found on BAT. I also couldn't find this part in the parts' manual illustration and none of the three parts distributors I contacted said they sell such a washer for this purpose.
Is there any reason for these washers to be where they were? Is it something done for track cars?
Related questions: how tight are the nuts to be tightened on the bolt that passes through the trailing arm and the bush? (So the arm deflects and touches the steel sleeve in the bush?) What if anything rotates or moves on this end of the trailing arm?
