Steve,
The temperature control door is the one I'm talking about. I think the manual I have calls it a mixing door. Per your instructions, replacement is from the engine compartment and does not require a dash pull as I thought. I was hoping I could access the door and move it manually to the heat position negating a replacement for now. If I decide to replace, do you recommend the Saab parts? Thanks. Don
The work taken to access the door is about the same as the work required to replace it
It's not actually a bad job as these things go. I found that removing the wiper linkage helped me gain a little more clearance to move the A/C evaporator unit, but my wipers were right-hand-drive so this may not apply to left-hand-drive.
The blower motor has two metal tangs one-third of the way down each side to hold it in place, and from memory the mixing door is free to remove once the motor casing is loose. It's all a relatively clean job and nothing like the work to access the stepper motors (incidentally, I reckon it is quicker to remove the dashboard complete, with all wiring, should you need access to the distribution drum or steppers. The partial dashboard removal advocated by some is actually more time-consuming, I find).
-Alex
