1 - 2 of 2 Posts
Hi all:
If this is an ABS hub, does anyone know how to get it off the disc? I have loosened the hat on the other side and it started to slide off the studs, but this mechanism follows it and stops at the top of the disc.
I have acquired these a long time ago, I don't know the origin and I don't care, I am just trying to get the discs off, but this thing on the back of the disc is still attached to the hats. There are some unfamiliar tabs inside the inner circle of these splines, but it is not obvious if they unscrew like a retainer ring, or if they are some form of big circlip.
Thanks for any help.
Automotive tire Wood Iris Rim Cameras & optics
Discussion Starter · #2 ·
Figured it out. After a good cleaning and penetrating liquid, the snap ring holes became visible and I worked it out. Toothed piece separated and the hub slid out of the disc.
Automotive tire Wood Rim Font Road surface
1 - 2 of 2 Posts
