1 - 5 of 5 Posts
I have appointments to look at two different 147s tomorrow in Ukraine. Both are 4 doors with manual transmissions. Both are advertised as 1.9 turbo diesels. How can I tell whether they are rated at 120, 150 or 170hp?
I have the VIN for both. Can I tell by that? What else can I look for?
1661792
you try to use online eper part catalog, and see what that vin number tells about car, search eper with google
It appears that it could be useful but I tried it on two different computers with safari and chrome and it would not accept either VIN. It just does nothing when I select the next button after entering the VIN
probably wrong way entered vin number or then eper version which doesnt work. I have used eper with my 156 vin many years ago with no problems. Double check that you enter the vin correctly, you can maybe try this site also https://www.fiatdalys.lt/en
Thanks. I've reached the conclusion that the answer can be found in the engine code. I.e., 973 A5.000 in a JTDM is rated at 150hp, which is the engine number listed on the aluminum plate of the car i drove yesterday. I'm hoping the one I drive tomorrow is 973 A6.000 indicating 170hp
147 (937)1.9 JTD (937AXD1A) 937 A2.000 115 HP Diesel2000 - 2010
147 (937)1.9 JTD 16V 192 A5.000 140 HP Diesel2000 - 2010
147 (937)1.9 JTD 16V 192 B1.000 136 HP Diesel2000 - 2010
147 (937)1.9 JTD 16V 937 A4.000 126 HP Diesel2000 - 2010
147 (937)1.9 JTD 182 B9.000 101 HP Diesel2000 - 2010
147 (937)1.9 JTDM 16V 937 A5.000 150 HP Diesel2000 - 2010
147 (937)1.9 JTDM 16V 937 A6.000 170 HP Diesel2000 - 2010
147 (937)1.9 JTDM 8V 937 A3.000 120 HP Diesel2000 - 2010
147 (937)1.9 JTDM 939 A7.000 115 HP Diesel2000 - 2010
1 - 5 of 5 Posts
