Want to strip out the front of '85 gtv6 but having trouble with the aircon/heater unit and the sound deadening/lining. Any ideas on how to remove it?
Yeah, disconnect the water heater tap but be very careful as the plastic is very brittle and it is impossible to get new heater taps. You can always cut the rubber hose before it connects to the heater tap (Make sure there is no coolant otherwise it will all leak onto your carpet). Also unwrap the black tar insulation around the air con hose and you should see a nut that you can undo.
The whole heater unit should pull out easily.
